Another Fordson project in 1/16th scale
Started by Chuck Doan, September 21, 2021, 08:17:48 PM
Lawrence@NZFinescale
A quick sandblast and a trip to the spray shop and that will look good as new!
It is cool to see the gold standard of weathering beeing hammered out right in front of you!
Grot and rust most realistic - and I agree with all
Thanks very much!
I skipped ahead a bit and finished one of the side chain drives. Made with 3D printed sprockets and Kyosho RC motorcycle chain. Grease is a mix of brown and black oil paint mixed with fine powdered dirt. Sprocket tips were polished with pencil lead. Chain guard (such as it is) made from .01 styrene. Painted a slightly different yellow as it was a later addition.
Acceptable. But please note the lower right hand sprocket tooth needs more pencil lead. -- Russ
Sami
With Chuck we are never disappointed.
Great work as usual !
Working on the wheels. Adding The Shining with Rub N Buff and Uschi steel polishing powder, using my hi-tech Foredom "lathe". Chasing it with thinned gouache also applied while spinning.
Krusty
Far and away the nicest reproduction of tyre steel I've ever seen. But we expected that.
Kevin Crosado
That's why it smelt so bad"
#132
Those fine and ultrafine striae, dents, scratches on the polished parts are absolute incredible.
And those slight nuances on the running surface between particularly stressed parts and the outher side is just phenomenal.
I am convinced it isn't just a matter of modelling at ist best, it is also a matter of observation skills...
Wowed again!
Peter
Just another masterpiece by the "MASTER"
Sami
