Rivet transfers
Started by DaKra, June 14, 2011, 12:34:53 PM
Saw these in the MM catalog that arrived yesterday.  At the price its worth getting some to try.
http://www.micromark.com/HO-Scale-Surface-Detail-Rivet-Decals,9968.html
Believe these are thermoprinted, the same way better quality business cards are made with raised plastic lettering.
Dave. I have purchased the Archer transfers. I can remember being 'shocked' at how small the single decal sheet was. These are quite large .. and there are two sheets per.
Here I managed to get a little bit of '3d effect' in this photo. This is two of the O scale rivet sheets ..
Yeah the MM sheets are big, assuming the quality is good, it looks like a good deal to me.  Plenty of rivets to practice and experiment with.
How did the Archer rivets work for you?
Are those hemispherical, or even close to it? In the photos it doesn't look like they stand out very much.
Ray, nope .. neither the Archer or these are true hemispherical. They do protrude a bit from the surface though.
Here's the Archer decals applied w/primer coat. Methinks they look pretty good. Ha. When I first looked at this photo I was like .. *meh* .. the .010" styrene melted and .. 'Oh Darn' .. but then decided that it was simply great modeling .. showing old damage on the critter's cab. :)
I saw those and thought to try them. My rivet embosser tool is good for strips and rivets at a panel edge but sometimes I need to have them in the middle of a panel. Now that I see the Ed's photos I will order.
Thanks guys!
MM doesn't really show a lot in the photo so I cant really tell, but it seems like the MM ones offer far less variety in spacing and off-set than is available from Archer. Also MM notes they are HO scale.....Archer offers multiple scales, and special purpose rivet layouts/patterns.
http://www.archertransfers.com/SurfaceDetailsMain.html
BTW...not all rivets are true half round or conical (despite what Grandt Line and Tichy wants you to think)...sheet metal rivets can be far less round to almost flat.....some rivets are also countersunk or partially embedded.
I've been meaning to try these for a long time. Rivets are always a problem in 1/87 scale. To date, I have been using gel super glue and trying to control position and size at the same time with limited success (very limited) Marc is right of course, rivets are not always perfectly convex. Similar to the discussion, I always liked the look of the handmade carriage bolts on big old barn door strap hinges, never one perfectly round.
Quote from: mabloodhound on June 15, 2011, 04:57:18 PM
MM also has 'O' scale rivet decals. http://www.micromark.com/O-Scale-Surface-Detail-Rivet-Decals,9967.html
If you look at the top right edge of the 1st photo I posted .. it says "O sca......."
NGPhil
I've been meaning to get this posted but haven't had a chance until now.  Not all rivet transfers are made equal!  I've been using Archer transfers for a while and love them.  The variety of sizes etc. available are excellent.  The Archer transfers have a much nicer three dimensional quality to them compared to the MM ones.
Take a look at the following high resolution scan of the MM product.  This hasn't been altered in any way and the product was straight from the package.  What is decieving about showing far away shots of the MM product is that there are massive variations in the resin vs the printed (black) details.  You can somewhat see this on the image that eTraxx posted.  Basically, the black printed lines/dots are nice and clean but the resin is a mess.  When you prime/paint your model w/ the MM details, this is a huge problem as the rivets are only half there half the time.
I'm guessing MM just started making these and haven't got the technology working 100% correctly yet and the resin is distorting after it's laid down.  Hope this helps someone who is looking at both trying to decide.
I see what you mean Phil. Thanks for showing that, looks like I'll be buying the Archer brand.
