Micro-Mark Pro-Etch Photo Etch System (Export Version)
Started by DarBeck, July 18, 2011, 12:42:33 PM
DarBeck
Hi all!
I'm thinking of buying a Micro-Mark Pro-Etch Photo Etch System (Export Version), but I need advice from you. Is this a good device. Is the quality of plates is sufficient. Do you have experience with this device.
respects
Darius Beck
I bought one a few years ago in the US (it came with the chemicals). It has everything you need to make a small amount of etched parts.  it comes with a few small pieces of sheet metal, but you can use sheet brass from anywhere you find it.
A quality etch depends on the even distribution of the etchant on the metal. That is why they include the bubbler. It provides a mixing action to the etchant so the metal surface is presented with fresh acid constantly. However, the bubbles are not enough so it is best to keep the metal moving as well. A commercial etch machine uses spray heads that provide force to the acid to speed up the etch and evenly distribute it; it makes for a predictable process. With the bubbles, you will need to keep checking the etch progress.
Thinner metal works best with this kit. I found it hard to judge the exposure of the pattern on the resist using light bulbs, but as I recall it worked OK. It is easy to wrinkle things in the heat laminator press so be careful.
The biggest challenge is to line up the patterns of a two-sided etch. You can figure that out, maybe with a folded pattern, or use tiny drilled holes as fiducials.
I believe Micro-Mark should be commended for offering this set. It does work with attention from the user.
Please be careful with the chemicals! Sodium hydroxide can be dangerous.
