Help wanted: How to make look plaster like old concrete
Started by mad gerald, March 12, 2012, 03:26:23 AM
Well, I think these results came out quite well....especially when they are in place, in context, and have some additionl dirt and staining on them.
The only nit-pick for your final pieces, is to not round off the outside corners and edges so much...even when tooled, and old, concrete squares /paving still generally has a pretty square-ish and straight-ish edge.
Quote from: mad gerald on July 13, 2013, 09:42:43 AM
... these pieces really look tiny ... is this H0 scale ... and what do they represent?
Yes, they are H0 scale pillars for the warehouse I´m building.
I went to the trouble of making board by board formwork, but I am not sure it is qoing to show in the end. But it was sort of fun making the little buggers.
They are a little under an inch tall.
Wow, those look even better in close-up than they did in the wider view!  -- Dallas
Well certainly nothing looks quite like cement than cement itself. Better yes.
Nice piers Hauk.
G'day all,
Quote from: Hauk on July 14, 2013, 02:10:47 PM
... ah, thanks ...
Here I have an example of some brandnew and older concrete paving slabs for a better comparison (as actually some of them had to be replaced on my front yard):
I changed the mixture increasing the plaster part in relation to the joint mortar part, but the compound is still a little fragile/crumbly ... colouring was done with artists water colour instead of acrylic colour because of the latter containing to much latex ...
