coming out of the modelling slump - slowly
Started by Barney, November 20, 2012, 12:42:06 PM
Nice project. Someday I want to do a mine hoist powered by an old truck.
Quote from: Ray Dunakin on November 24, 2012, 07:26:44 PM
  Sounds very Lane Stewartish . Actually , I have been thinking on those lines recently as well . I have two pictures of old vehicles being used as mine winches . The first is an old lorry with its rear axles removed and a winch mounted on the back and , my favourite , a Ruston-Bucyrus RB17/19 off its crawlers and with its jib removed doing the same job . They would both make good models . The pictures can both be found in " Small Mines of South Wales" by A. J. Booth .
Nice roof ! , details please
See you could not built something without including OD!
Roof covering is "tissue paper" cut to suitable size strips - dipped in a dilute mixture of PVA glue and water (same mix as you would use for scenery / ground cover) and cover the roof - crinkle it a bit to leave air bubbles to get a lifting effect of the roof covering if required . the tissue paper normally has a dull side and a slightly gloss side use both to give a slightly different effect -
Hosted on Fotki
Looking more-n-more interesting all the time.  Like the change to the vertical cooling barrel.  Cheers, Dallas
5thwheel
Looking good Barney. One question (coming from rainy Oregon I can't help but notice) how are you going to keep the rain run off from the cab roof from getting into the engine and stalling it out?
Bill Hudson
Fall down nine times,
get up ten.
I will have to think this one out !! Watch this space ( Gordon help how do I wriggle on this one)
Looking for an old inner tube
Bill, you will need to refer back to the original blueprints (page 1) , a drawing worthy of DeVinci!
As you will see reference is made to a corrugated roof over the whole contraption, now obviously modern developments with materials have now reached a stage where the tar paper roof is the better option .... As captured in the tissue build above. This immensly and weather proof structure will ensure that no rain actually falls on the vehicle roof and thus there are no issues re water run off on to the engine.
.fivers in the envelope please Barney
British innovations at its best - and when I find that old inner tube all it wants is a bit tucked under the bonnet or hood or what ever you want to call it
Hosted on Fotki
Quote from: 5thwheel on December 06, 2012, 09:12:31 AM
  Easy . Put a gutter on the roof .
  Do I have to do all the thinking around here !
5thwheel
Quote from: gfadvance on December 06, 2012, 11:56:52 AM
What a relief.  I was concerned that the engine would get flooded out when really needed.   ;D
Bill
Bill Hudson
get up ten.
5thwheel
Bill
Bill Hudson
get up ten.
