Spares or repairs
Started by Barney, January 26, 2020, 10:47:33 AM
A start of a new project !  A De Winton vertical boiler loco "of a sort" - a small diorama 1/24th scale -18in gauge (On3 bits)
I have found a few odd bods of this loco -One called "Arthur" water tank in centre and engine on the end and using a jack shaft drive
another (unnamed ) wheels inboard and 18in gauge and converted to run on Oil using a marine engine and a few others with that many different changes and modifications -so this will do me a small critter from the Huffikins workshops
photo 1 - A prototype
          2   the main components  water tank /fuel tank /engine side plates cylinder block /crank and reversing lever /boiler and nearly ready for detailing nuts / bolts /rivets
photo 2
photo 3 underside showing cog drive and wheels
photo 4 trial fit of parts
Your usual superbly clean and accurate construction. Satisfactory. -- Russ
Les Tindall
Great stuff!, add rust and there's a superb little diorama piece. As Russ said your work is always very sharp and clean looking.
Les
Vertical boiler loco ended up with the Marine engine version and gear driven - Nuts /bolts and rivets now added - but still finding more - bits removed and corrosion / rust added most parts just trial fitted (to aid painting - some just leaning) ready for the paint shop and the ditch were it will end its life  with the weeds
end view
other side
other end
looking down
Nice clean work, except for all the corrosion which looks...corroded.
Someday I need to build an HO scale small steam launch. I'm marking this thread as reference.
Excellent! How did you create the corroded appearance?
