flat pack in 1-35 scale and dapto dogs.
Started by 1-32, June 25, 2015, 03:54:10 AM
Carlo
Excellent, Kim. Keep the photos coming please.
Carlo
Wait until airline security x-rays that and sees all the metal wires (RR track).  Air terminal building will be evacuated, etc. etc. ::)
Nice work Kim.
8)
yes-  airport security my opion the more the better .there are too may fools who want to kill innocent people in the world.basically i can not take into the cabin too much metal or controllers.it might get through once or twice but then you might hit a tight stop and you are stuck.also when you they inspect your bags you don't do the unpacking it is done by a pair of extra big hands that have not been trained for delicate detail.the more i build the more the model is being split up.the security sensitive parts into hold in a hard shell case ,these will be protected by custom designed panels that will absorb too much vibration.the very delicate non security items with me.
really you would have to be a bit of a nut to worry so much but part of it with me is that i look at it as a part project in logistics ,sure if you had heaps of money all this packing would not be a problem like he shipping of paintings .but i dont have a lot of money -
cheers kim
hi all.
my little loco-Dapto is finished again 1-35 scale running on 9 mm track.finished size 43 mm long 25 mm wide and 55 mm heigh.
cheers and all the best.
Satisfactory. What a charismatic little critter. -- Russ
yes Russ something to fit in your coat pocket.
Hi Kim, then congratulations on the successful small Freelance model.
hi all
i just looked at my first posting about the flat pack-Dapto it was about 1 year ago i feel that it will be finished Febuary next year.
so.
i have  filled in all the gaps of late-cover for the dock area and resin water-now the detail ,backdrop[this will be the top of the traveling box].the box section in the water is where a work barge will be moored.total 5 pieces now and adding
cheers kim.
Very nice  - its got atmosphere and its "different "
I agree, and I'm glad the tracks don't run in a circle this time. The current effect is more credible. -- Russ
hi ray and russ how are you all.
one of the big problem of all this small base board large scale stuff is getting a good track layout.the passing loop is the basic- using 9 mm gauge helps in getting it all to fit.
cheers kim
good morning all.
work on the Dapto traveling model continues.there have been 3 new developments of late.
1-i have started work on the work barge .this vessel covers the ply wood insert in the resin water.this is a little barge more of the tender design that would have been a work station.water side construction  companies typically used this size of vessel.wood and styrene so far.
2-i have changed the layout of the buildings at the back.when i looked at the original design it was getting looking very rectangular .to change this i broke the row of buildings and took away the bushes and made it into a court yard .this also has another purpose to show off my'"ice" delivery push bike ,more detail will be added but the concept works.
3-the start of the backdrop 4 mm plywood.will be painted also duel purpose.the 2 purpose top of traveling box inner protection.the 2 layers of protection area the hard shell carry on size suit case with the inner shell made of ply and padding it should work.
cheers.
