Not actually a Union Gas Engine !!
Started by Barney, January 25, 2024, 08:47:58 AM
In the background of the above photo a tank has taken aim at the critter. Perhaps its new colo(u)r will be "Exploded Green". Uh-oh .... -- Russ
Are you feeling  OK Russ or is it an age thing !!!!!
Ever since I lost my cotton pickin' mind I feel great! -- Russ
Slow going at the moment and still lots to do - due to some 1/35th stuff but all went wrong !!!
yes its GREEN  but if its good enough for Mr Bond it will pass for me
Throttle / speed control still to do  along with choke control and fuel lines
large tank across the bulk head for Paraffin as we call it - Kerosine for people across the puddle
tank on side rear for Petrol ( for starting ) and lube oil
jobs to do more weathering oil leaks and rust but not to much as she is "loved "
And forgot the tools for he box and some rail and scenery should give it a bit of life
Another cracking job done and a fine looking loco . I look forward to seeing it in the flesh in a couple of weeks time .
That little contraption looks extremely adequate, especially when you click on the photos and see them full size. The model's progress is acceptable. -- Russ
As Kermit the Frog crooned "It's not easy being greeen", but it is definitely a nifty little diesel.
Les Tindall
The difference between the unfinished and painted models is striking. The paintwork brings this little masterpiece to life.
Very clean build! :o
And i especially like the colours - they would also be adequate on my Büssing. What colours did you choose?
Quote from: Peter_T1958 on May 01, 2024, 07:06:07 AMVery clean build! :o
  His usual colour !
