19th Century Cornish Stable
Started by granitechops, March 14, 2012, 02:45:02 AM
Don,
certainly looks like a well whitewashed wall to me ............. although think I may add a few very diluted grey washes to it with maybe the odd touch of brown just to age it slightly
granitechops
#61
Did a weak black wash with a hint of grey all over, when dry did a brown wash where the dust from the hay would be prevalent
I Like this shot
Don in sunny Devon, England
granitechops
#62
But in places the change from brown to black is a bit too abrupt
granitechops
Having said which I do like the way the brown fades around both sides of the feeder where the hay being pulled out of the rack would have flicked the dust off the wall a bit, perhaps?
That's looking good, IMHO. Of course it all depends on how recently painted the wall is supposed to be, but I would think that in a horse stall dust would accumulate pretty quickly.
If you're concerned that some areas might be too dark you can always tone them down with a wash of white.
granitechops
Quote from: Ray Dunakin on March 19, 2012, 12:35:19 PM
It did occur to me to perhaps try a white wash but with the wall upside down so that the colour would collect on what would end up being the the lower edges, so still retaining the dust on the top edges.
Time frame, quite a while since the last horse departed, but building run down & not redecorated, and building used for repair work, so more dust
But that does not mean that I might not do a photoshoot with a horse in there just because I can!
granitechops
Done the lintel over the window, with it being recessed it gives the cornish character I think
granitechops
#67
Door lintel
Edit. this is not the final wall finish, just coloured for the look
granitechops
While waiting for glue to dry, made up a couple of ladders
a 3 part extending ladder & a widow cleaners ladder
granitechops
As a lot of interior detail will be visible, but wont be get-at-able when assembled, at this stage the only fixed parts are the two walls the hay rack will be mounted on & the base, the rest is just a snug dry fit to ensure it all fits properly, so I can then finish & detail the interior, So ignore the floating wall etc.,
its work in progress
granitechops
#70
The wall appears to be floating due to the need to get levels right for the drainage channel seen in the centre there
As the base is not solid, its a styrene & card lamination, I wanted to avoid building it to top surface level & then cutting out as that would have weakened the structure
granitechops
Working on the tack room wall as that will be the most inaccessable part, Framework for hollow wall designed to support floor beams, with spacers at 16" centres on back wall
granitechops
#72
Tack room wall cosmetic spacers added as part of front card leaf & wall given coat of texture, opposite wall added & fixed
granitechops
3 walls done complete with lintel over door
granitechops
So turn attention to gable wall, corner strengthener same dimension as wall thicknes, framing door way & window with scrap bits of wood that will only show one face, if that
