The play ground
Started by Daniel, July 24, 2022, 03:39:48 AM
Stuart
Daniel
#31
This idea was also thrown upon my head those days.
IMG_0019 (2) by Daniel Osvaldo Caso, on Flickr
No, it is not for the toilette...
IMG_0020 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0021 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0023 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0024 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0026 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0028 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0030 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0033 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0034 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0035 (2) by Daniel Osvaldo Caso, on Flickr
The stroke below in the image above had a bad alignement due to lack of proper attention. The upper one was done second...
IMG_0037 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0038 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0039 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0040 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0042 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0041 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0045 (2) by Daniel Osvaldo Caso, on Flickr
The above cutting is done in 0,5mm styrene.
IMG_0047 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0049 (2) by Daniel Osvaldo Caso, on Flickr
Next is 'Çraft card' something more popular in the U.S. than here where one must go to specialized paper shops to find it. Hobby shops don't have it.
IMG_0062 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0064 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0065 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0066 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0067 (2) by Daniel Osvaldo Caso, on Flickr
These weren't cut at once because i wanted to see if i was getting enough control in the process to trust it for real work...
IMG_0068 (2) by Daniel Osvaldo Caso, on Flickr
... and i was delighted with the result!
IMG_0069 (2) by Daniel Osvaldo Caso, on Flickr
I decided to give the device an adjustable stop...
IMG_0070 (2) by Daniel Osvaldo Caso, on Flickr
... so to ensure the distance between the windos would be exact...
IMG_0072 (2) by Daniel Osvaldo Caso, on Flickr
I made one with a rest of brass angle...
IMG_0076 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0077 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0078 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0079 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0080 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0081 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0083 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0084 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0085 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0086 (2) by Daniel Osvaldo Caso, on Flickr
Djusting the register you can make bigger holes in two or more steps but.
IMG_0088 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0089 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0002 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0004 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0005 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0006 (2) by Daniel Osvaldo Caso, on Flickr
This was an a lot better stop...
IMG_0007 (2) by Daniel Osvaldo Caso, on Flickr
The underside nut for adjusting the sliding register...
IMG_0008 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0009 (2) by Daniel Osvaldo Caso, on Flickr
Such cutting tools are cheap but differ in quality.
They come in many, many sizes and cuting shapes.
Probably they are all made in China but the three sizes i bought from this range are good enough for me and low priced... yet!
Daniel
Dis you say building's 'windows'?
Yes, that is why the last double row
Daniel
Quote from: Stuart on July 28, 2022, 06:16:41 AMWell done!
Stuart
Thank you again, Stuart!
Great to know you find it good enough to pay attention!
Daniel
Daniel
Making acceptable roof braces for coaches and other vehicles by hand was for me doable until my eyes started voting for the oposition a decade or so ago.
Then i started to seek alternative tri cks as cutting sectors from rings cut grom PVA or other material pipes but i wanted an a bit more precise method. Here the story in images:
Yes, again the Proxxon MP-400.
IMG_0010 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0011 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0012 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0014 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0013 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0015 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0017 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0018 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0022 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0031 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0032 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Wow, so much great stuff here! I especially like your method of making the sides of the passenger car. Very clever!
Daniel
Thank you Ray.
You probably don't know me yet but i have been silently enjoying and sharing your work and your delightful photography collection on Nevada's mining for years. So it is an honour to read your comment.
I am slowly visiting member's work threads and soon i will reach your work again.
Daniel
Daniel
This is an a bit more complex project to explain but i hope the images will better than my blah-blah. Still, if someone want to ask, whatever, i'll be pleased to answer.
I built this first version about a decade ago and it is still working perfectly.
(I am considering a more versatile version but that will come when it comes.)
DSC00721 by d.caso, on Flickr
That was a lucky chopping of an old Cannon scanner.
The long steel rod is 8mm diameter and was cut to fit, drilled to take removable punches...
https://www.flickr.com/photos/daniel_1_32_scale/15458973797/in/album-72157648103236323/
DSC00724 by d.caso, on Flickr
DSC00742 by d.caso, on Flickr
DSC00743 by d.caso, on Flickr
DSC00744 by d.caso, on Flickr
DSC00745 by d.caso, on Flickr
DSC00746 by d.caso, on Flickr
DSC00747 by d.caso, on Flickr
DSC00749 by d.caso, on Flickr
DSC00750 by d.caso, on Flickr
DSC00752 by d.caso, on Flickr
DSC00753 by d.caso, on Flickr
DSC00754 by d.caso, on Flickr
DSC00755 by d.caso, on Flickr
DSC00756 by d.caso, on Flickr
DSC00758 by d.caso, on Flickr
P1420224 by d.caso, on Flickr
The composed wood work was no more than lack of more wood but has done a lot of work and is still as new...
P1420227 by d.caso, on Flickr
P1420228 by d.caso, on Flickr
DSC00762-001 by d.caso, on Flickr
DSC00764-001 by d.caso, on Flickr
DSC00763-001 by d.caso, on Flickr
DSC00782 by d.caso, on Flickr
DSC00786 by d.caso, on Flickr
DSC00788 by d.caso, on Flickr
DSC00785 by d.caso, on Flickr
DSC00784 by d.caso, on Flickr
DSC00771 by d.caso, on Flickr
DSC00772 by d.caso, on Flickr
DSC00773 by d.caso, on Flickr
DSC00774 by d.caso, on Flickr
DSC00775 by d.caso, on Flickr
https://www.flickr.com/photos/daniel_1_32_scale/15040248984/in/album-72157648103236323/#:~:text=%5Burl%3Dhttps%3A//flic.kr/p/oV4d2E%5D%5Bimg%5Dhttps%3A//live.staticflickr.com/3950/15040248984_02cbb9f2f0_c.jpg%5B/img%5D%5B/url%5D%5Burl%3Dhttps%3A//flic.kr/p/oV4d2E%5DDSC00776%5B/url%5D%20by%20%5Burl%3Dhttps%3A//www.flickr.com/photos/daniel_1_32_scale/%5Dd.caso%5B/url%5D%2C%20on%20Flickr
DSC00777 by d.caso, on Flickr
DSC00778 by d.caso, on Flickr
P1420233 by d.caso, on Flickr
More in next message because i don't know how many photos is possible in une.
Daniel
The cross table is the usual Proxxon but i've seen there are now some much cheaper made in China.
I don't dare to suggest them because i have learned how variable is the quality of China stuff but have heard some good comments about.
P1420235 by d.caso, on Flickr
DSC00810 by d.caso, on Flickr
DSC00809 by d.caso, on Flickr
DSC00808 by d.caso, on Flickr
DSC00807 by d.caso, on Flickr
DSC00806 by d.caso, on Flickr
DSC00805 by d.caso, on Flickr
The punches were made some from 6mm brass for the body and steel rod for the punches self but others were made by epoxying togueter pieces of telescopic brass tube because i had no more rod and my wallet was already crying.But all that worked also great through the years...
But i noticed more was possible.
Probably the most important thing was the idea of using selfhealing mat for all work instead of specific dies(it was an iidea of my wallet.)
... and it works fine even rivetting 0,5mm brass...
DSC00849 by d.caso, on Flickr
DSC00850 by d.caso, on Flickr
DSC00851 by d.caso, on Flickr
DSC00811 by d.caso, on Flickr
DSC00812 by d.caso, on Flickr
DSC00813 by d.caso, on Flickr
DSC00814 by d.caso, on Flickr
DSC00815 by d.caso, on Flickr
DSC00816 by d.caso, on Flickr
DSC00817 by d.caso, on Flickr
DSC00821 by d.caso, on Flickr
DSC00820 by d.caso, on Flickr
DSC00823 by d.caso, on Flickr
DSC00824 by d.caso, on Flickr
DSC00825 by d.caso, on Flickr
DSC00856 by d.caso, on Flickr
DSC00857 by d.caso, on Flickr
DSC00858 by d.caso, on Flickr
DSC00859 by d.caso, on Flickr
DSC00861-001 by d.caso, on Flickr
DSC00867 by d.caso, on Flickr
DSC00863 by d.caso, on Flickr
DSC00864 by d.caso, on Flickr
DSC00866 by d.caso, on Flickr
DSC00869 by d.caso, on Flickr
DSC00874-001 by d.caso, on Flickr
DSC00880 by d.caso, on Flickr
But then more ideas started to apear...
DSC01118 by d.caso, on Flickr
More in next message.
Daniel
I noticed there was some side play so added two wooden supports that are now useful for tool storage as you'll see later.
DSC01153 by d.caso, on Flickr
DSC01152-001 by d.caso, on Flickr
DSC01151-001 by d.caso, on Flickr
DSC01145 by d.caso, on Flickr
... and ideas kept coming ...
DSC01155 by d.caso, on Flickr
DSC01156 by d.caso, on Flickr
I built later the device in the last drawings but by then i was interested in making a tool that could emboss and may be also cut hexagonal bolt heads.
The mayour problem was to ensure the alignment between the hexagonal punches (made from pieces of Allen keys and the dies: little set screws. The solution came too:
DSC01160 by d.caso, on Flickr
DSC01163 by d.caso, on Flickr
DSC01164 by d.caso, on Flickr
DSC01185 by d.caso, on Flickr
DSC01183 by d.caso, on Flickr
DSC01182 by d.caso, on Flickr
DSC01180 by d.caso, on Flickr
DSC01177 by d.caso, on Flickr
DSC01793 by d.caso, on Flickr
DSC01794-001 by d.caso, on Flickr
DSC01795 by d.caso, on Flickr
DSC01797 by d.caso, on Flickr
DSC01817 by d.caso, on Flickr
DSC01820 by d.caso, on Flickr
DSC01823 by d.caso, on Flickr
DSC01830 by d.caso, on Flickr
DSC01831 by d.caso, on Flickr
DSC01833 by d.caso, on Flickr
DSC01834 by d.caso, on Flickr
DSC01835 by d.caso, on Flickr
DSC01841 by d.caso, on Flickr
I need a pause so more later.
Daniel
Daniel
DSC01804 by d.caso, on Flickr
DSC01803 by d.caso, on Flickr
DSC01847 by d.caso, on Flickr
DSC01849 by d.caso, on Flickr
DSC01850 by d.caso, on Flickr
DSC01851 by d.caso, on Flickr
DSC01855 by d.caso, on Flickr
DSC01856 by d.caso, on Flickr
DSC01858 by d.caso, on Flickr
DSC01861 by d.caso, on Flickr
DSC01916 by d.caso, on Flickr
DSC01968 by d.caso, on Flickr
The styrene profile in the above photo is not as sharp as the Evergreen one and the material is thicker so for Evergreen i made another jig. But the idea is clear now, i hope
So far was clear that i would be mak8ing many more jigs so prepared a number of wooden strips to fit the groves of the Proxxon crosstable...
DSC01946 by d.caso, on Flickr
DSC01947 by d.caso, on Flickr
DSC01948 by d.caso, on Flickr
DSC01950 by d.caso, on Flickr
DSC01951 by d.caso, on Flickr
DSC01952 by d.caso, on Flickr
DSC01954 by d.caso, on Flickr
DSC01959 by d.caso, on Flickr
DSC01961 by d.caso, on Flickr
WARNING!
i have read somewhere than cutting, sanding or milling the selfhealing mats may be dangeours for the health so i ensure i do it with the mask on, gloves and with the vacuum working. I did got cancer but that was a couple of years before, not by then or later.
I had three types of selfhealing mats. Experience told me the cheapest, harder types are the best ones for this purpose.
DSC01964 by d.caso, on Flickr
DSC01965 by d.caso, on Flickr
DSC01966 by d.caso, on Flickr
DSC01967 by d.caso, on Flickr
DSC01974 by d.caso, on Flickr
Back to the sector plate for certain jobs is important to hold it at an specific angle. The simplest solution works great:
DSC02186 by d.caso, on Flickr
DSC02188 by d.caso, on Flickr
DSC02190 by d.caso, on Flickr
DSC02191 by d.caso, on Flickr
The cutting tool was made with a piece of the same seel rod from the scanner. The blade is a standard one from the plastic circle cutters...
DSC02192 by d.caso, on Flickr
DSC02194 by d.caso, on Flickr
DSC02196 by d.caso, on Flickr
The tiny lip at the right in the photo is important to sup[port the blade in position...
The sector plate is used for both, cutting and riveting...
DSC02197 by d.caso, on Flickr
DSC02202 by d.caso, on Flickr
DSC02208 by d.caso, on Flickr
DSC02204 by d.caso, on Flickr
DSC02207 by d.caso, on Flickr
Through the years i have had plenty of good moments with the riveter & Co. but i have also learned several things may be improved, often a lot and found out more applications to be prepared. That is the reason whay i want to make a new one but there will be a little basic difference this time:
IMG_0001 (523) by Daniel Osvaldo Caso, on Flickr
... and this crosstable is 460mm long X 240mm wide, almost as heavy as i (...) and came with a very heavy steel column 55mm diameter and the double moving head too.
I bought it years ago draming to make a milling machine from it but that never happenned so thimngs must get their new chances too. It is from Woolcraft, old German made so it will be a nice party...
Daniel
What a massive undertaking! -- Russ
Stuart
I have discovered that sometimes it takes as much or even more effort and time to create the tool for a particular procedure than it does to make the part the tool was designed to produce.  But then, that's all part of the modeling fun, right?
Stuart
Daniel
Quote from: finescalerr on July 29, 2022, 12:34:51 PMWhat a massive undertaking! -- Russ
Well, yes, Russ.
The crosstable will be part of a much more versatile 'system' than the first riveter.
I want to make also a removable bridge across the 240mm with aprecision rail so a Proxxon milling motor can be pushed & pulled along. That way i hope to be able to make acceptable scribed panels (wood, styrene, MDF or whatever)and other simple milling jobs without needing to rest on laser nor CAD.
It will also, eventually,provide some support if my eyes decide it's time for a bigger scale.
You may be noticing, my mayor interest is not to have a collection of models but to enjoy the making finding affordable and, for my limited skills & wallet, doable ways to get things done.
So far i have sold several portable layouts built until 2010 but since then, my best works, use to end up being dismantled for recycling 'strategic' components as laser cut doors, windows and other things, 3D printed stuff and the such or go to charity. The point is above all i hate not to have room for new projects, not to have paper for new drawings as much as not having materials or tools.
Daniel
Daniel
Now a pause in the tools & methods thing and a bit of real modeling.
The little house with the barrel tiles roof you have seen is still waiting for the definitive surrounding trees but i have found images with the 'traveling tree brigade'(jumping from diorama to the layuout and then to another diorama just to check and learn about posibilities but never fastened to the groun yet) posing for the camera some time ago so here come the trees (and later the how to).
Also about the rest of the greenery, of course.
IMG_0102 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0103 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0105 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0107 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0108 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0109 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0140 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0141 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0142 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0143 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0145 (2) by Daniel Osvaldo Caso, on Flickr
This is the architect leading the works at the bridge...
IMG_0129 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0054 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0055 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0056 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0058 (2) by Daniel Osvaldo Caso, on Flickr
More later.
Daniel
