Rewanui - a 1940 West Coast NZ layout in 1:64
Started by Lawrence@NZFinescale, February 08, 2021, 08:47:25 PM
As well as the water vat I've been working on the coal stage as the two sit side by side on the layout.
The vat would have been well maintained and thus weathered paintwork was a good approach.  The coal stage was a far rougher structure and would have faced damage from years of loading/unloading coal.  Inspired by Mr Doan's work, this prompted me to look for ways to model weathered wood in 1:64 in a way that was not too time intensive (remember that all these models are part of a larger whole, not ends in themselves).  First experiments are earlier in this thread, but here is progress on the structure.
A 2 part clip together print this has proven quite quick to do on the real world side.  I've printed a few of them and this is the result of the second experiment.  Steps were:
  • prime
  • filter (only a play with this as I hadn't used it before)
  • paint gray
  • dark enamel wash
  • spray chipping fluid (or hairspray)
  • topcoat
  • remove paint with tape
  • Another wash to inside surfaces
This works well and is very quick because the details are all in the print.  Now I've done my proof of concepts I can take a little more care with the final version.
Despite the lack of updates various things have been progressing on the layout - more development and technical than visual though.
However I have got to a stage with scenic experiments (and photostacking) where I can present some progress.
The image here is just a short length of rockface and adjacent track.  None of it's finished, but it is getting there.  It's been something of a challenge to represent the flora of the place.  Now i'm bedding my methods down progress should be a bit faster.
Lawrence
The result is more than satisfactory. With which software did you do the photostacking and is there actually a freeware for it?
If the scenery still is unfinished, please be sure to post again when it is complete! -- russ
Quote from: Lawrence@NZFinescale on November 14, 2021, 08:48:59 PM
Lawrence
I´m with Russ. If this is unfinished business, I can not wait to see it when it is done.
Is there a pinion rack in the middle of the track, by the way?
Fantastic work on the scenery.  The clump of grasses hiding behind the bushes in the left fore ground looks, at first glance, like an oversized fox hiding in the weeds.
Quote from: Design-HSB on November 14, 2021, 11:48:48 PM
Thanks Helmut.  I used the free trial version of Affinity based on recommendation here.  Previously I'd use PS Elements with the Elements+ add-on. Affinity is better, waaaaay faster and reasonably priced.
Quote from: Hauk on November 15, 2021, 03:06:26 AM
Cheers Hauk.
The centre rail is on the Fell patent and is plain symmetrical rail.  On this line it was used solely for braking.  There were special vans with a gripper brake.  The locomotives were also fitted with a centre rail brake, but one of the old drivers told me they were never used other than as a holding brake when stationary. (He did use the loco brake one day, out of curiosity, resulting in a large bang and many yards of centre rail ripped up.  Something failed under the loco).  The Fell patent was used for ascending elsewhere - there were gripper wheels that clamped the side of the rail.
There's a blog post on my journey to model the centre rail here: https://nzfinescale.com/more-fell-deeds/
Good looking rock face. I especially like the ferns, what are they?
Quote from: Bill Gill on November 15, 2021, 10:13:54 AM
Like many here I like to hoe my own row, so almost all of the things on the layout are scratchbuilt or from my own products.  As I make the products they reflect my interests so are dead right for the layout.
The ferns are etched in 0.1mm brass.  Sprayed up and coloured in the flat.  I've found that 3-4 fronds make a reasonable looking plant.  While real ferns generally have far more this works quite well in practice.  I curve the fronds with fingers and set the bases into a dob of gem adhesive set on some non-stick sheet (used label backing).  Finish with a sprinkle of short staple dark brown static fibre (representing the very hairy bases of these plants). Gem adhesive is a viscous, high build acrylic (I think) that remains a bit tacky and rubbery.  This keeps the fronds as placed and they don't fall over (much). I do a sheet of plants, and then peel and stick.  Generally they tack themselves in place and I reinforce with white glue.
Quite a few of the plants in this view are brass actually.
https://nzfinescale.com/emporium/finescale-foliage/ferns/
That seems to work so well I think I'll replace the living plants in my backyard with etched brass. And they don't need water, a boon in our drought stricken state. -- ssuR
Quote from: finescalerr on November 15, 2021, 11:40:43 AM
If you let me supply I'll be able to retire!
Lawrence, it didn't occur to me that the ferns are etched brass. Very nice! Imodel in HO scale and had unsuccessfully looked into the possibility of laser cutting both ferns and sumac fronds from origami or cigarette paper. Thanks, you have renewed my interest in new possibilities.
WP Rayner
Beautiful work Lawence... the rock face is excellent, very convincing and a good balance of foliage. Nothing fanciful about this at all... well done.
Whisky Workbench
