Spares or repairs
Started by Barney, January 26, 2020, 10:47:33 AM
Satisfactory. Now let's see how it looks after you paint it. -- Russ
I love it, especially the corrosion look. I am curious about the paint job.
Corrosion of plastic - some of the flatter parts is just a 5 thou layer of plastic card  distressed with a knife blade plenty of pocking and scraping then finish of with some 400grit wet & dry sheets then glue to the side /flat panels stippling the adhesive  to create metal laminating - the more solid panels is just lightly bounce a ball end tool over it using a Dremell type drill on a slow speed - some of it needs going over again to get it more in clusters rather than just isolated dents the undercoat of rust colour will show this up so A few more minutes work is required.
some photos to follow
first rust undercoat and it shows some un-natrule "dings and scraps" especially were you can see 3 or 4 "dings " in a row so its back to attack with the dremel ball and a bit more sanding to thin the rust layer down then a bit more rust undercoat
the middle top pipe into the boiler needs a bit more texture to simulate rust and bits of asbestos lagging
the  Dremel ball tool just let bounce across the surface on a slow speed
Until you posted the photos and description I thought you had developed a new technique: Modeling with cottage cheese! -- ssuR
A Few shots - I think the amount of corrosion / rust is to heavy and the whole engine needs burying/covering in years more of junk
still I might get it right one day !!!
the other side
the end
the other end
It looks outstanding from every angle. Satisfactory. -- Russ
One small nit to pick: it seems like the heavily corroded areas are almost the same color as the rest. Perhaps a bit more rust color would be appropriate in those areas?
