Back to the Big
Started by Chuck Doan, August 01, 2012, 07:02:58 AM
I am that other modeler. I'm just too modest to admit it. -- ssuR
Yes Nick, that is sufficiently fawning. For now.
Quote from: Chuck Doan on November 30, 2012, 03:07:09 PM
  Phew , for a minute there ,  I thought I'd overdone it .
More  progress on my krustaceous window;  I am almost done with the sagging upper sash, and this weekend I made a decal for one of the panes. I had several pictures of old Lucky Strike decals and decided to try one. After some testing, here are the steps I used:
I opened a picture of an old L.S. window decal in Photoshop Elements and cropped and cleaned the image.  I find that my printer makes bigger dots on gradient images, so I used the paint bucket and brush to make each color solid (The final weathering will be done after application)
Since I was going to print on clear (Testors) decal film, I turned the white cigarette package a slight grey, and then I re-whitened the interior leaving just an outline of grey to print as a cutting guide (white areas will not print on clear paper). Then I flipped (reversed) the image for printing.
I imported the image into Word and sized it to fit the window pane. I made several copies and then printed them on the decal paper using the "best photo" setting on my Epsom printer. I also turned off the "high speed" setting for the best image.
I cut out one of the decals and trimmed around the package shape. Then I gave it three coats of Dullcote spray, waiting 5 minutes between coats.
I applied the decal in the usual way to the backside of the glass pane and let it dry. I brushed thinned Polly-S off white to fill in the clear interior of the package shape and let it dry. (An even solid coat is not required). Then I took some 70% Isopropyl alcohol on a small brush and dabbed at the back of the decal. This partially dissolved the white paint and caused some crackling to occur. Using photos of actual weathered decals,  I moved the paint around to create different amounts of color and also made some chipped areas.
Great idea(s)!
I am especially impressed by how precariously that center pane is just about to fall out! don't sneeze!
 ;D Don't have to say anything...the stupid looking grin on my face says enough.
Outstanding plus  (Gordon's door and frame don't stand a chance ) lovely workmanship - perfection
    dribbling
Uff! Chucks work put our work into prespective again (Hope that is the right translation :-\).
Very inspiring indeed,
Peter
Real neat idea with the decal!
Anders
Thanks very much! I will need to put the decal technique to the test as I broke that pane last night.  :'(  I underestimated the delicacy of the larger panes (pains?) of cover glass. Oh well, twice as fun the second time, right?
Chuck,
not sure if you need or ever will larger pieces of glass but I found 1x3 and 3x3
I need to pick up the 3x3 and see if they are any good.
FYI; Ranger makes the 3x3
That is so excellent.  And now you have to re do it??
I'm sure it will be better that the 1st if at all possible.
Thanks Jerry, I hope it will be better. Thanks Marty, after this one, i'm not sure I would make anything much bigger, but it's good to know. 3X3 sounds scary to handle!
