Jacobs Creek Mk 2
Started by Barney, July 31, 2023, 07:44:48 AM
Having another go with a bit more hope to finish This Time !!!!!
Scale 1/35th - climate hot and sticky with a touch of Murphy's War The start of a new "power house " Stone ends and open sides - first the floor A layer of plastic card with a top layer of stone slabs cracked in places lego blocks for the engine bases.
Diorama Debris 1/35th bricks on  thin card for motor joints
Stone End walls Diorama Debris 1/35th stone blocks on a cardboard template and on the other side Plastic Card with detail (example shown on a smaller building for the Diesel engine driven generator )
End Walls up and detailed inside  and a base ground cover started
Steam engine and Hot oil engine trial fit on there brick base - boiler started with cobbled base (Diorama Debris )
Also the Overhead crane beam trial fit
Steam engine will be for a overhead pulley /belt system for the saw mill and other machines in the mill
Hot Oil engine is to drive a Large compressor
Now loads of pulley / belts/ brackets and fixings for all the beams and the completion of the engines and boiler
I'm always fascinated by the technical stuff you're cranking out 'just like that'!
Extremely adequate so far. Charismatic, too. -- Russ
The walls are brilliantly done, both outside and inside.
nk
That is a great start. Keep it going
I love it! Are the stone blocks plaster castings?
Ray I use Diorama Debris Silicon moulds https://www.dioramadebris.co.uk And colour the plaster with mortar mix powder colours  - Photo of silicone moulds are odd things to photo but here goes
Finishing of the Steam Engine and Hot oil engine - every time I look I find something else to add but I think I have it finished at last  - now ready for the spray for a coat of undercoat (Humbrol Rules)
A few shots of each side not to boring I hope !! some parts trial fit only hence the wobbly look ! to make the spray job easer
Side 1 steam engine
Steam engine Ends
Hot Oil  engine Sides
Hot Oil Engine Ends
Still found more to add and modify !!!!
