HUFFKINS Mine
Started by Barney, January 04, 2018, 12:55:55 PM
The Cement mixer - The photos with the measurements were supplied some years back by a friend of Gordon the "flying Scotsman" The single photo is of a later version  The Drum had to be detailed for me to continue the build due to the frame which will hold all the in & out chutes  goes on next the base for this is an acrylic tube with plastic card ends  - detailed with Master Club nuts /bolts
The engine will be a vertical cylinder type - on the lines of  a Fairbanks Morse engine  - some good UTUBE stuff available on these engines driving Early Cement Mixers
The Start of the mixer
later version but the same idea
Thoughts on the engine
That's going to be nice! -- Russ
detail_stymied
some very interesting plant getting built here.
s.e. charles
At first I was skeptical of a small mixer being powered by a steam engine, the only ones I had seen were much larger and sometimes the steam engine itself was mounted on the ground beside the mixer rather than a a mobile mixer, but that misapprehension was quickly dispelled with a look online where several small tea kettles powered mixers around the size of your project. Go for it!
Here's one YouTube video that fits the size:  https://www.youtube.com/watch?v=QCX928FU-h8
Greg Hile
Im going to use a Fairbanks Morse Petrol / Paraffin type machine as in diagram this is a vertical cylinder type but they do use Horizontal cylinder types as well in the Photo
loads of them on YouTube these engines are often called "hit & mis" https://www.youtube.com/watch?v=idohWe4TT-w
Horizontal type
here is inspiration Early drum type mixer with vertical "hit & mis" engine https://www.youtube.com/watch?v=2Mw9Y6gY05g
Quote from: Barney on January 15, 2018, 12:44:32 PM
Your precise styrene work never fails to amaze me.
detail_stymied
s.e. charles
