The play ground
Started by Daniel, July 24, 2022, 03:39:48 AM
Daniel
I've found some of the prototype images from O&K catalogues but i may find a lot more in similar not identical versions...
Image0792 by d.caso, on Flickr
Image0590-1 by d.caso, on Flickr
Image0590-2 by d.caso, on Flickr
Image0589 by d.caso, on Flickr
Image0590 by d.caso, on Flickr
This has been my very best 3D printing design ...
10  5 2012 004 by d.caso, on Flickr
... and, again, the skip chassis is from R. C. Link range...
9  5 2012 356 by d.caso, on Flickr
The grau bedding was made in wood...
9  5 2012 355 by d.caso, on Flickr
9  5 2012 353 by d.caso, on Flickr
9  5 2012 350 by d.caso, on Flickr
9  5 2012 349 by d.caso, on Flickr
9  5 2012 348 by d.caso, on Flickr
9  5 2012 347 by d.caso, on Flickr
8  5 2012 481-001 by d.caso, on Flickr
8  5 2012 480-001 by d.caso, on Flickr
... and here i've found the lady..
FM 24 8 2011 069 by d.caso, on Flickr
As i told you, even those days i barely measured one or two things as the total lenght or so. The rest is all Magoo's free interpretation.
Daniel
Daniel
Quote from: finescalerr on August 31, 2022, 12:02:48 AMDaniel, what notifications did you receive? -- Russ
Well, Russ, after you instructed me and i followed that, i've got notification for this, Kim's and Bernhard threads and a couple more. Some days ago only from Kim's & Bernahard and now nothing for several days.
But computers don't like me and that is reciprocal so often they just make fun of me not knowing once they may get a flying above the channel experience.
But would be great as the notifications would work.
Thank you.
Daniel
Daniel
#107
While (still) searching for the images of the corrugated plate pastel work found this that may be interesting for someone. Not necessarily the way i did  it but the concept:
29 11 2011 137 by d.caso, on Flickr
29 11 2011 139 by d.caso, on Flickr
29 11 2011 140 by d.caso, on Flickr
29 11 2011 141 by d.caso, on Flickr
29 11 2011 143 by d.caso, on Flickr
29 11 2011 145 by d.caso, on Flickr
29 11 2011 146 by d.caso, on Flickr
O.k., first try not so great but still...
29 11 2011 147 by d.caso, on Flickr
No, still not 'there'but playing with it is great...
29 11 2011 160 by d.caso, on Flickr
29 11 2011 164 by d.caso, on Flickr
29 11 2011 171 by d.caso, on Flickr
Yes, DAS clay.
29 11 2011 172 by d.caso, on Flickr
29 11 2011 173 by d.caso, on Flickr
A bit too ball so let's see if...
29 11 2011 174 by d.caso, on Flickr
29 11 2011 175 by d.caso, on Flickr
I am sure by slightly pressing pieces of sandpaper of different grain in a, yes, as chaotic as possible way, it will provide interesting effects and, eventually a big pannel for getting from it a silicone rubber mould if you want mass production...
 B.t.w.: O&K 0-8-0 20"gauge in a sugar mill's 164km line in Argentina...
Ledesma AGN-1 by d.caso, on Flickr
Daniel
Well, it is taking some work to find the corrugated plates roof images but meanwhile you get a chance to get used to Magoo's chaos...
9 12 2011 043 by d.caso, on Flickr
This is a wellknown, very flexible, amazing strong packing material
9 12 2011 034 by d.caso, on Flickr
9 12 2011 042 by d.caso, on Flickr
It is easy to work but very dificult to paint. Next time, instead than airbrush primer i will use BISON contact glue very diluted with toluene and spoil a soft brush for giving the foam a very thin layer if i don't manage to get the right spray adhesive as 'primer'...
9 12 2011 041 by d.caso, on Flickr
9 12 2011 039 by d.caso, on Flickr
9 12 2011 038 by d.caso, on Flickr
9 12 2011 036 by d.caso, on Flickr
9 12 2011 040 by d.caso, on Flickr
Daniel
Daniel
I forgot...
10  5 2012 007-001 by d.caso, on Flickr
10  5 2012 006 by d.caso, on Flickr
10  5 2012 369 by d.caso, on Flickr
10  5 2012 368 by d.caso, on Flickr
Yes, i made many not deep longitudinal cuts in the direction of the grain to add variation...
10  5 2012 360 by d.caso, on Flickr
... and also plenty of undeep cuts in every thinkable direction at the end section of the roof...
10  5 2012 367 by d.caso, on Flickr
10  5 2012 359 by d.caso, on Flickr
10  5 2012 358 by d.caso, on Flickr
10  5 2012 364 by d.caso, on Flickr
No, don't expect to see the finished building: soon after the photos it was replaced by another more interesting one.
(That was ten years ago!)
Daniel
Daniel
Still underway to the corrugated plates...
24  5 2012 005 by d.caso, on Flickr
24  5 2012 007 by d.caso, on Flickr
24  5 2012 009 by d.caso, on Flickr
24  5 2012 015 by d.caso, on Flickr
25  5 2012 038 by d.caso, on Flickr
25  5 2012 037 by d.caso, on Flickr
25  5 2012 036 by d.caso, on Flickr
25  5 2012 035 by d.caso, on Flickr
(The images are all from my old Flickr, not the current one.)
Once again, some very interesting and clever work!
Daniel
Thank you, Ray.
That is all stuff from ten and more years ago and too see it again gives me plenty of idas for new approaches.
Great that you're still enjoying my nonsense!
Daniel
Daniel, your modesty honors you, but you show us here interesting techniques and really high model building art.
Daniel
Thank you for your words (...also if they are really confusing for my lone brain cell!)  :)
Daniel
Daniel
20  5 2012 022-001 by d.caso, on Flickr
20  5 2012 023-001 by d.caso, on Flickr
20  5 2012 024-001 by d.caso, on Flickr
20  5 2012 001 by d.caso, on Flickr
20  5 2012 003 by d.caso, on Flickr
20  5 2012 004 by d.caso, on Flickr
20  5 2012 014 by d.caso, on Flickr
WARNING!
Don't try it with styrene: the friction would smelt it around the cuts.
Don't expect it to go as easy as cutting Balsa: one must do each cutting slowly and gently so to give the saw the time to bite, chew and digest!
Daniel
P1700404 by d.caso, on Flickr
... and that was eight years ago, when i was still trying to keep a bit of 'normality' at home...  ;)  :D  ;D  :)
Magoo
Daniel
I was building "ROCHEFORT", a layout representing a 20" imaginary line somewhere in also imaginary France for an amazing finescaler in the UK whose work was focus on brass locos and rolling stock, al 1/32 scale. less than 60cm deep, room was very scarse so i learned many tricks to fool the eye about space.
An important element for that was to have an a bit hiding street partially visible only from some spots and occupying a maximum of 2" depth at the right end but all the rest only 1".
I will some day tell about the layout but i want to show here a for me funny, easy trick.
Let's the images tell the story and the... :D  ;D  :)...'method'... ;D  ;D  :D
The street was taking the upper level so to hide a long track running at the foot of the backdrop...
At the right end of the street would be a small restaurant with a small terrace at the front and the rest of the street, with it's just 25mm maximum depth, would me in principle just a row of false fronts...
P1680898 by d.caso, on Flickr
P1680874 by d.caso, on Flickr
P1690258 by d.caso, on Flickr
The image below shows the tiny right end of the street practically only visible from the oposite end of the layout so i cgave it a stairs, a door and other minimal details to sugest 'there is more' (I already explained, i am a born liar.)...
P1680862 by d.caso, on Flickr
(the white foam with the pencil lines was a first sketch for the restaurant.)
This was the situation at the end seen from above...
P1680861 by d.caso, on Flickr
P1680863 by d.caso, on Flickr
P1680869 by d.caso, on Flickr
This would be the 'terrace'...
P1690256 by d.caso, on Flickr
... and, since the rest of the false fronts where already underway, all i needed was something to fill in the  (in the image black) space between the row of buildings and the restaurant...
P1690251 by d.caso, on Flickr
I had no idea what to do to avoid the conceptual repetition and in such 'don't knowing' is wheremost good ideas get born...
This was the left end of the row...
P1690978 by d.caso, on Flickr
... this was the moiddle...
P1690976 by d.caso, on Flickr
and thi was the restaurant...all of them half way between sketch and model...
P1690939 by d.caso, on Flickr
P1700341 by d.caso, on Flickr
P1700342 by d.caso, on Flickr
P1700344 by d.caso, on Flickr
P1700361 by d.caso, on Flickr
P1700362 by d.caso, on Flickr
P1700398 by d.caso, on Flickr
P1700405 by d.caso, on Flickr
P1700416 by d.caso, on Flickr
P1700417 by d.caso, on Flickr
P1700418 by d.caso, on Flickr
P1700419 by d.caso, on Flickr
P1700431 by d.caso, on Flickr
Notice that the thicknes of the building body was just part of the 25mm available...
... and here we go...
P1700456 by d.caso, on Flickr
P1700457 by d.caso, on Flickr
P1700458 by d.caso, on Flickr
P1700461 by d.caso, on Flickr
P1700462 by d.caso, on Flickr
Punching small holes in the now painted black foamboard is no work and inserting & glueing the twigs is something one does whistling...
P1700466 by d.caso, on Flickr
P1700467 by d.caso, on Flickr
P1700468 by d.caso, on Flickr
P1700469 by d.caso, on Flickr
P1700471 by d.caso, on Flickr
P1700474 by d.caso, on Flickr
P1700469-001 by d.caso, on Flickr
P1700471-001 by d.caso, on Flickr
P1700473-001 by d.caso, on Flickr
P1700475 by d.caso, on Flickr
P1700485 by d.caso, on Flickr
P1700492 by d.caso, on Flickr
P1700491 by d.caso, on Flickr
P1700510 by d.caso, on Flickr
The protruding bits of the twigs at the backside were simply cut with pliers onve the glue was dry...
P1700527 by d.caso, on Flickr
And now  the skeleton of the lie
P1700529 by d.caso, on Flickr
P1700522 by d.caso, on Flickr
P1700519 by d.caso, on Flickr
P1700520 by d.caso, on Flickr
P1700523 by d.caso, on Flickr
P1700524 by d.caso, on Flickr
P1700525 by d.caso, on Flickr
(I used variations on the same principle in several other situations and must say it has proved to be 100% effective at fooling the eyes.
Daniel
Daniel
#118
Just in case you are curious, this was the concept for the track plan and the reason of the elevated street...
P1660595-001 by d.caso, on Flickr
A small yard for the tall factory where a sector plate connect the entrance to the hidding track that run to a three track turntable hidding under the landscape and ending at my very first photo in this thread...
Daniel
Daniel
7   8  2012 1184 by d.caso, on Flickr
7   8  2012 1185 by d.caso, on Flickr
7   8  2012 1186 by d.caso, on Flickr
7   8  2012 1191 by d.caso, on Flickr
7   8  2012 1192 by d.caso, on Flickr
7   8  2012 1193 by d.caso, on Flickr
7   8  2012 1195 by d.caso, on Flickr
7   8  2012 1196 by d.caso, on Flickr
... but also...
7   8  2012 1201 by d.caso, on Flickr
7   8  2012 1199 by d.caso, on Flickr
... and eventually...
7   8  2012 1198 by d.caso, on Flickr
Magoo
