The nicest scene i modelled so far
Started by Daniel, September 12, 2022, 12:36:02 PM
Daniel
This is about the second of the three ongoing dioramas.
As always, critics, comments and certainly questions welcome.
It started with a baseboard 120cm X 78cm, exactly as the other two dioramas...
P1190187 (2) by Daniel Osvaldo Caso, on Flickr
P1190188 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0006 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0007 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0008 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0014 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0017 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0001 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0003 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0004 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0005 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Daniel
#1
Yes, plaster bandage as during the old days long before i.
IMG_0002 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0009 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0010 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Daniel
Daniel
#5
IMG_0013 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0036 by Daniel Osvaldo Caso, on Flickr
IMG_0038 by Daniel Osvaldo Caso, on Flickr
IMG_0039 by Daniel Osvaldo Caso, on Flickr
IMG_0040 by Daniel Osvaldo Caso, on Flickr
IMG_0067 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0068 (2) by Daniel Osvaldo Caso, on Flickr
I had no idea about what kind of buildings would come but wanted it to have a bit the character as organic architecture brought until machines invaded the human brain and from there the world. So the cut spaces where at this point totally arbitrary, as you'll see later...
IMG_0069 (2) by Daniel Osvaldo Caso, on Flickr
One of the things i wanted to avoid was falling in the now usual totalitary pattern of right angles but from there i couldn't know how tall were the buildings going to be. So i started by building with foamboard the 'towers'fitting the cuttings on the ground...
IMG_0070 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0071 by Daniel Osvaldo Caso, on Flickr
IMG_0072 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0097 by Daniel Osvaldo Caso, on Flickr
IMG_0098 (2) by Daniel Osvaldo Caso, on Flickr
... and suddenly i 'knew' ( :o  :D  :) wyhat to do... (... did i?)
IMG_0099 by Daniel Osvaldo Caso, on Flickr
IMG_0101 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0102 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0103 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0121 (2) by Daniel Osvaldo Caso, on Flickr
(It is such a delight to play with volumes...)
IMG_0122 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0123 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Good start there, Daniel
but it took me a while to get through all the pictures a lot of them looked the same.
Cheers Kim.
Daniel
#7
IMG_0124 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0110 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0111 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0112 (2) by Daniel Osvaldo Caso, on Flickr
... and the endless sequence of changes started.
IMG_0113 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0134 (2) by Daniel Osvaldo Caso, on Flickr
Magoo
Daniel
#8
Quote from: 1-32 on September 13, 2022, 01:04:16 AMGood start there, Daniel
Cheers Kim.
Thank you, Kim.
Sorry for the repeated images. won't happen again.
Daniel
Yes I am more into Disco mania short and to the point with a bit of stuff in between.It just took me a while to get to the reply part.
cheers
Daniel
#10
Daniel
#11
IMG_0038 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0039 (2) by Daniel Osvaldo Caso, on Flickr
In the layout and other dioramas i had built several neat half timber houses but wanted a more... organic version so decided to go now in a different way but needed a try first...
IMG_0129 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0130 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0133 (2) by Daniel Osvaldo Caso, on Flickr
That went fine.
My intention wasn't to build something likje this (yet)...
but half way between neat and that.
That was o.k. for me so i went further...
IMG_0022 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0019 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0018 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0065 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0066 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0071 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0073 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0074 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0077 (3) by Daniel Osvaldo Caso, on Flickr
IMG_0079 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0082 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Daniel
#12
IMG_0043 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0044 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0050 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0051 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0060 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0061 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0062 (2) by Daniel Osvaldo Caso, on Flickr
Yes, but this time must because must fit the next building!
IMG_0015 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0016 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0023 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0024 (2) by Daniel Osvaldo Caso, on Flickr
The shop front was laser cut from a drawing i've made with Sketchup and someone translated to CAD for me and made the cutting in 1mm MDF (i may be wrong but i believe it was forum member Lucas Gargoloff who did all that for me but my memory...Well, you know.) It was built in three layers and this is being it's second life...
IMG_0025 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0027 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0045 (2) by Daniel Osvaldo Caso, on Flickr
IMG_0047 (2) by Daniel Osvaldo Caso, on Flickr
Magoo
Daniel
#14
