January 21, 2022, 03:40:35 PM *
Pages: [1] 2
Author Topic: Large scale Panther  (Read 33638 times)
Dave Fischer
Jr. Member
« on: November 06, 2016, 11:51:58 PM »
I had posted a while ago that I was TEMPORARILY putting aside my locomotive project to try to get a model ready for the IPMS Nationals in Phoenix (two hour drive) in the summer of 2018. I had started this BIG Panther project all-the-way-back in 1993, revived it briefly in 1999, and this past summer dusted it off (literally) as something that COULD get done in time! The scale is 1/9 (like my tractor and Sturmgeschutz) making the hull about 27" long. The gun overhangs the front by about another 6", so the task of transporting the model is not insignificant, and being able to drive it to the competition is a welcome opportunity...
The turret is all new, and several of the old parts will be redone. Construction is mostly styrene with plenty of resin castings (track links, suspension parts and wheel disks) from my own masters and molds. As always, no commercial, found, kit parts or 3D printed parts will be used in any way-- all scratch. The green on the turret sides is is the putty for texturing the surface, and the whole hull will look like that before it gets painted. More to come!
Dave Fischer
Jr. Member
« Reply #1 on: November 06, 2016, 11:54:55 PM »
Let's see if I can slip in a couple more photos...
« Reply #2 on: November 07, 2016, 12:28:54 AM »
Adequate. -- Russ
« Reply #3 on: November 07, 2016, 05:05:43 PM »
Very, very impressive, both in size and execution!
Ray Dunakinís World
Dave Fischer
Jr. Member
« Reply #4 on: November 12, 2016, 11:34:50 PM »
Thanks, fellas! Maybe some paint is in the not-too-distant future. Recent discoveries have me working backward just now, taking a couple of things off to rework them a bit... More  to come.   DF
Dave Fischer
Jr. Member
« Reply #5 on: May 09, 2019, 02:27:29 PM »
What did that say... 2016? Well, the Summer 2018 deadline seems to have slipped away, but the project is still moving ahead. There are a few pieces left to build before the paint can happen, and the wheels and tracks are off so they can be coated with mud. Weathering will be interesting since the actual vehicle had such a short life (completed in late September of 1944, disabled and captured December 19 of the same year). Paint damage and rust will be minimal, so mud and dust will be my medium of choice, with a few scrapes from moving around. The episcopes around the commander's hatch have mirrored plex prisms, so they function like real periscopes. Here are a few pictures that should look a little different from the ones before...   DF
Dave Fischer
Jr. Member
« Reply #6 on: May 09, 2019, 02:39:24 PM »
A couple more photos... The gas cans are NOT in their final colors! Next is a shot of the rear plate-- the bolts for the various access panels include cotter pins to allow the nuts to be loosened without them coming off. The jack between the exhaust pipes is the one exception to the minimal weathering rule-- the design of the suspension often gave trouble and the jack was likely used often. Finally the spare track links hung from to turret sides to provide a little extra metal between the crew and the enemy anti-tank guns.    DF
« Reply #7 on: May 12, 2019, 04:23:39 PM »
Wow! Nice work!
Ray Dunakinís World
Dave Fischer
Jr. Member
« Reply #8 on: May 16, 2019, 10:08:08 PM »
Thanks Ray! I was beginning to think I stepped into a Bermuda Triangle or something...   DF
« Reply #9 on: May 16, 2019, 11:22:56 PM »
Oh? Are you near Bermuda right now?
You've built a seriously outstanding tank model but the forum has been quiet for the past ten days or so. You know how it is here; if you get a couple of compliments here it's equivalent to a standing ovation at Carnegie Hall.
Dave Fischer
Jr. Member
« Reply #10 on: May 17, 2019, 07:34:03 AM »
Well, not Bermuda... but there IS supposed to be a similar time-space twist centered somewhere around Gila Bend-- not that far from Tucson! It sure HAS been quiet for a while, though. Hey, c'mon, Russ... I was hoping to achieve adequacy. Guess I'll keep working.   DF
« Reply #11 on: May 17, 2019, 09:39:40 AM »
You did achieve adequacy, and then some. I'd go so far as to say the tank is satisfactory ... so far. -- Russ
Online Online
« Reply #12 on: May 17, 2019, 04:12:06 PM »
 Careful , Russ, you donít want to overdo it with the praise . The poor chap might believe heís doing a decent job of that bit of a tank he is cobbling together !
WP Rayner
Feral Curmudgeon
« Reply #13 on: May 18, 2019, 08:53:54 AM »
Amazing work... truly setting a standard here. I'm curious as to how you replicated the welds.
We've got a full tank of gas, half-a-pack of cigarettes, it's dark and we're wearing sunglasses.
Dave Fischer
Jr. Member
« Reply #14 on: May 18, 2019, 10:03:38 AM »
Almost everything attached to the Panther was quickly welded on, so I've had plenty of opportunity to practice! These welds are hardware store window caulk shot through a syringe with a tapered spout. I use a Luer Lock syringe with a replaceable tip to make cleaning and size changes easier. Unfortunately, the nicer welds on the rear deck and the boxy bases of the exhaust pipes were done years ago with a cheap generic caulk that is no longer to be found--replaced by products better for windows but not nearly as good for fake welding! I will put a how-to with pictures together to make this information more useful...  Thanks, all!   DF
Pages: [1] 2
